93 LX
JDM H22A1
5 sp. Manual
Here's a list of my problems, as always, any help is apreciated.
1) After my car warms up it has an odd idle. It goes to about 1500 back down to 500 (revving up and down). From time to time I can turn on/off the heater full blast and the revving will subside.
2) While driving around, I will get a CEL but if I turn the car off, it will go off. So my question is, is there anyway to check the code while the car is running? It only did this after the ECU was recently reset, and it threw a code 36, which I believe is strictly a JDM code and has something to do with 4WS.
3) After the swap was done, my car wouldn't shift into reverse. It has been checked right at the tranny, and it just feels like there is no gear there at all. It feels the same inside of the car. I called HMotors (where I purchased the motor from) an they said I needed to replace a bushing that is found inside the tranny. Does anyone know where this bushing it is, how much work is involved in replacing it, and what its name is?
JDM H22A1
5 sp. Manual
