throttle position sensor and the Manifold absolute pressure sensor
    I recently purchsed a venom 400 ecu from h23accord and i was wondering where are the throttle position sensor and the Manifold absolute pressure sensor located? and where would i tap into them?
    H23?
    Where do i tap into the TPS and MAP
    H23?
      your tps sensor is located directly on the opposite side of the throttle rotor on your throttle body. and the map sensor is located in a "black box" on the passenger side of the firewall. you should see vaccum lines coming out of the box; remove the cover(s) and your map sensor is inside. about which wire on these sensors you tap into, im not sure. do you have the instructions for the venom 400 that tells how to test which wire you'll be tapping into? you'll also need a voltmeter to help you out.
      5.6L V8 32V DOHC
      JDM HERITAGE - US BUILT
        Thanks for tha info na Dont think it comes with instruction but im sure i got get a voltmeter
        H23?
          call venom and ask them specifically how much voltage should the wire be reading to which you'll be tapping into. you don't wanna tap into the wrong wire(s)
          5.6L V8 32V DOHC
            Does anyone have any pics or the color code for the wires i splice into?
            anyone with a venom 400 holla at me on AIM CB7Tuner915! ineed a little help !!!!
            H23?
