tranny oil
    tranny oil
    Ok im about to go 5speed, i was wondering what good oil can I put on the tranny ? I heard they put motor oil on them, not sure tho ? What oil will be better guys... its a h22a4 tranny
    MY H22 SEDAN
    honda oil? i used 1030 full syn in mine
    Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
    But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
      i put oil in mine and it scratched really bad in the cold. i went to soemthing thicker.
        Honda MTF? Thats what I run in mine...not a prob. since I did my 5spd swap over a month ago.
          isn't there some sort of book that tells you the proper weight...some kind of manual for owners that lists these sort of things...normally kept in the glove box...written by honda?
          Or you could just go to honda and get the good stuff that has been said by members (including me) to reduce 3rd gear grinding vs gear oil/motor oil.
          ____
            so my best bet is to go to HONDA nd ask ?
            MY H22 SEDAN
              Yeah just get the weight that it originally came with and use Honda trans. Fluid.
                so none of that motor oil , get pure HONDA tranny fluid... just wanna make sure guys
                MY H22 SEDAN
                  Yeah I would stick to Honda tranny fluid. Same goes for your power steering. I use nothing but Honda power steering fluid.
                    aight thanks
                    MY H22 SEDAN
                      i like pennzoil sync. mesh myself...
                        on ur transmission
                        MY H22 SEDAN
                          yes get honda fluid only...search the boards...the part number for the new and improved stuff is given. Order from majestic...my local dealer charges out the ass for EVERYTHING...your dealer prolly will too.
                          What I meant was, if you don't use honda's new fluid (which has improved 3rd gear shifts) then read the owners manual and find out what viscosity to use.
                          ____
                            Originally posted by 93JDMBeast View Post
                            on ur transmission
                            not on it...
                            but in it
                            search it here on the site, theres all
                            kinds of threads bout pennzoil synchromesh...
                            there was even one just not that long ago that was
                            talking bout the gm sync mesh, i heard that is similar
                            if not the same fluid
                            i like it so far, but im more than sure if u get the honda mtf
                            u shuld b cherry
                              10w30 or Honda MTF.
                              "The Turtle"
                              DD/Trail Rig/Mud Bug
