When installing an electric oil pressure gauge... can u tap into the stock oil pressure sending unit wiring or do u have to use the sending unit they give u?
Oil Pressure Gauge Install
ok another question. Is installing the sender using an oil filter adapter a good way to measure pressure or tapping into the block like using a tee-fitting better? i dunno if its my sender, my gauge, or just the location it is in giving me an inaccurate reading. at idle it reads 90 psi when cold and after warm up it reads 25-30 psi... i kno im suppose to be reading 10 or so at idle. then when i rev it up to about 2-2.5 rpms it reads 95 psi... which at 3 suppose to read like 50. anyway help me out guys. tanx
http://theoldone.com/articles/oilpressure/
im not sure what you were saying about mounting it... but your gonna want to do it like that.
Originally posted by SenseiAccordok another question. Is installing the sender using an oil filter adapter a good way to measure pressure or tapping into the block like using a tee-fitting better? i dunno if its my sender, my gauge, or just the location it is in giving me an inaccurate reading. at idle it reads 90 psi when cold and after warm up it reads 25-30 psi... i kno im suppose to be reading 10 or so at idle. then when i rev it up to about 2-2.5 rpms it reads 95 psi... which at 3 suppose to read like 50. anyway help me out guys. tanx
Originally posted by cb9h23the reason OP is so high @ start up is because of the bypass valve. 90 psi until warm up is normal, for that location. thats telling how much presure is on the bypass valve. the best way to go ,imo, is to use a tee fitting between the block and oe sender. that way you get the correct oil pressure of the motor.
