Driver's Door Stuck in Locked Position!
    after you drill the hole, this is what you're trying to move.
    that small black lever is what holds the door closed. when you have a hole drilled, you can manually move the lever with the screwdriver. that allows the black wheel to spin free. later.
    Avoiding dirt at all costs
      Thnaks G ..
      But I'm going to The Stealership in the morning ..
      I've had it with this POS .. lol
        G . I went to eBay
        and found this guy that has this part ..
        http://cgi.ebay.com/ebaymotors/ws/eB...id=p2759.l1259
        I know it says right front, and I'm assuming that it's the passenger side.
        I emailed him and asked him if he could find me one for the drivers side with auto belts.
        Let me know if that's what I need in the link above .. albeit for the drivers side.
        It looks like the part when I compare it to your pictures in the DIY link.
        Thanks man!
        Tomi
          I just bought this one on eBay ..
          I hope all 90-91's were auto-seat belts lol!
          http://cgi.ebay.com/ebaymotors/ws/eB...DLVI%26ps%3D54
          Tomi
            Bump .. is that last link (the one I purchased) the right one?
            Thanks
            Tomi
              As long as you drill the hole exactly where the DIY says, it's not a terribly difficult task. I had to use an air hammer because I didn't have a long enough drill bit, but once I broke the latch into pieces, all I had to do was shove on the door a bit, and it popped open.
              Good luck bro!
              SOHC Non-VTEC F-series for life
              "It is the fools prerogative to utter truths that no one else will speak."
              -Morpheus (The Sandman)
                Good luck bro!
                LOL .. omg man .. err, thanks .. umm, can I borrow a few tools?
                oh and .. uhhh ........... an air compessor?
                Tomi
                  make sure on your latches from now on to use lithium grease like once a year. That helps the parts from sticking to each other. You just need to slather it in there and open/close the door a few times. Make sure it gets in there really well.
                  I hope you fix it soon! Vegas must be hot right now, same as AZ. Don't you love fixing stuff in 100+* temps?
                  member's ride thread
                  91 Accord SE 176k
                    its funny that i see this thread cuz two days ago this happen to me and its still stuck so im crawling threw the passenger side to get in lol but what im going to do is after seeing the DIY thread im just going to drill out the lock thing and go to the junk yard and pick up a door i dont think i have the skills to put that new latch on fuck that
                      i had the same problem and all i did was replace door latch i went to the jy and did it myself if that helps any
                      http://www.cb7tuner.com/vbb/showthread.php?t=154842
