i have this i my 93 accord ex and was wondering if there are any recent pictures taken of the vacuum lines that anyone can put on here
h23 intake manifold
i was trying to go by this
http://www.cb7tuner.com/vbb/showthre...ght=h23+vacuum
it says to connnect #21 to my throttle body but it doesn't have a nipple. one big one for charcoal canister only, no little vacumm nipple
where 21 is supposed to go there is a map sensor with electrical connector
i have all of them already hooked up just wanted a confirmation if it was right
the closest of the three coming out of the control box is hooked up to far right side of the plenum(bottom of the two nipples)
the middle of the three is on the plenum to the right of the throttle body(second to the right)
the back of the three is hooked up to the back of the plenum on the right side
the first nipple on the plenum right of the throttle body is hooked up to the intake vacuum tank(next to battery)
fuel pressure regulator is hooked up to front of intake plenum
hose off of intake tube connected to starting air valve
cruise control is connected to far right side off plenum(top of the two nipples)
Originally posted by d112crzy View PostJust make sure all your vacuum lines are hooked up to something. Doesn't really matter where they go.
As long as they are all hooked up to the TB or plenum, chances are everything is going to work correctly.
The bypass control solenoid valve....thats bolted to the firewall directly behind the plenum? I have something bolted there with a couple of vacuum lines run to it, but my car had the f22a1 originally....so that must be a different valve/sensor. What could it be? Maybe for the auto rear engine mount? In which case I can get rid of it now....or is it something else?There are no black and white suspension answers!!!!!!!!!!!
Originally posted by frootloops View PostThey are just showing the bypass control solenoid in a better location then where it is actually located (bolted to the underside of the runners).There are no black and white suspension answers!!!!!!!!!!!
Originally posted by mndude07 View PostYeah, that's what I figured....thats the "black box". I still wonder what the thing is bolted to the firewall on my car then.
Originally posted by frootloops View PostHave a picture?
I guess if its not on your car, then it must be something for automatics?
