does anyone know of a diy on installing camshafts on an h22, one with good detailing...this is my first time ever messing with internal worx...open opinions welcome....thanx fellas, happy tuning!!
help installing camshafts h22a4
Suprisingly I can't find any DIY's for camshaft replacement.
What info are you looking for?
My 5.7 LS1 Holden Ute
damn pretty much the whole process....you see i got an h22 swap but the head was taken off and the camshafts were also taken off...unknown reasons...stupid wannabe mechaniks!! well i want to put them back on i just need a good detailed ay to do it..becuz i read that u have to torque down the bolts in a certain numbered order??
Heart and Brain Transplant fail I had to pull the plug
My new best FRIEND!!!
Good is your freind. all i googled was " h22a camshaft install guide "
http://www.honda-tech.com/showthread.php?t=1857587
you can buy the manual for the 97-01 prelude with the h22a4. at your local parts store it will have a complete tear down and rebuild of the engine!
http://www.cb7tuner.com/vbb/showthread.php?t=91030 <--MY RIDE!
http://www.cb7tuner.com/vbb/showthread.php?t=140230 <--MY ongoing ENGINE BUILD!..
Not hard just unblot the cam caps,make sure that the bottom end is set at tdc on the No.1 piston install the cams with gears make sure the cam gears have the up arrow pointing up as well,put the cam caps back on and torque them down with specified torque sequence.
Shouldn't take more then 30mins.
Originally posted by Tippey764 View PostGood is your freind. all i googled was " h22a camshaft install guide " hmmm really thats always worth a try thanx...
ima peep this out real quik^^^
Originally posted by motobmx105 View Postyou can buy the manual for the 97-01 prelude with the h22a4. at your local parts store it will have a complete tear down and rebuild of the engine!
Originally posted by Darkcloud View PostNot hard just unblot the cam caps,make sure that the bottom end is set at tdc on the No.1 piston install the cams with gears make sure the cam gears have the up arrow pointing up as well,put the cam caps back on and torque them down with specified torque sequence.
thanx for da help fellas
Originally posted by Darkcloud View PostDo you have the cam gears on them as well,if so when installing the cams look behind the cam gear you'll see an arrow when at TDC the arrows should be pointing up.
Originally posted by CATCH24 View Postok yea i see em...but wen im puttin them on how can i assure that theyre tdc exact becuz by sight i can be wrong, do i allign them with anothern line or hint or watever?? thanx for ur input ...
There is arrows on the front of the cam gears as well
Hope that helps you good luckLast edited by Darkcloud; 08-18-2009, 03:19 AM.
