Ok i searched but couldn't find answers to my questions. I've recently noticed my coolant resevior bubbling and such when the car is idling for awhile and when its off. I figured it was the heat from the turbo setup but i sat next to the car after i turned it off yesterday and noticed the fans never came on. I remembered seeing insulation melted off a wire that went to the radiator due to the open wastegate. But forgot about it (whoops )
I searched and found out that i should test the wires going to the radiator. So i tapped the wires on the a/c fan i guess u would call it. Grounded the black wire and ran a line from the blue wire to the ignition wire. Turned the car over and sure enough the a/c fan came on but not the other fan. I could easily hook them both up to the same switch(when i put i on a switch) but i'd like it to act normal again and turn on without any outside aid. I'm not sure what to check next. Could it be the fan relay? Can someone direct me to where that is? I also tried turning on the a/c to make the fans come on but that didn't work. The car overheated like a month ago but that was the only time. Temp gauge always reads normal
