Correct me if im wrong...
    Ok in brandon ms where i stay gas in 2.30 a gallon, I was on E and i put ten dollars in my gas tank, i went 118 miles today off that ten and im practically back on E like i started, now gas is 118 and its 2.30 a gallon, 2.30x4=9.20 118/4=29.5. So does that mean im getting close to 30 miles a gallon???
    I calculated 25mpg...
    wat?
      Originally posted by C91BLX7 View Post
      Roughly
      that another word for barely???
        sorta close...
        10 dollars * 1 gallon / 2.3? dollars = 10.00/2.30 gallons = 4.35 Gallons
        (4.347826)
        118.?? miles / 4.35 gallons = 27 mpg (27-27.14)
        If you are a manual then manual oil change, engine oil change, spark plugs, air filter, 35psi when cold in tires, should get you to 30.
        Depends on the gas you get though. Around here (north east texas) I get about 30.? during the summer and 27.7 during the winter.
        If you want to get super technical, this isn't the best way to determine actual mileage for a couple or reasons. Your speedo doesn't read correctly...none do...mine is generally 3% off. Even our 00 accord is off, 50-55 is the only time its spot on.
        But you didn't want to get super technical
        ____
          Originally posted by bcjammerx View Post
          sorta close...
          (4.347826)
          thanks man
            I would just run your tank full, reset the trip meter and then when it hits the E again use that mileage divided by the number of gallons you just put in. Thats the best way to get the most accurate reading or MPG.
              I got 27.5, but do what said above. I always go a little bit from full then fill her back up after I use about a half tank, then divide the miles traveled by gallons you put in to fill her up.
              "The Turtle"
              DD/Trail Rig/Mud Bug
                WHAT??? lol I Think your closer to 25ish
                1990 Accord LX Sedan~Sold
                1993 Accord EX Sedan~Sold
                1995 Suzuki GSX-R 750~Totaled
                  27.5 is only if he fill up with the same amount of fuel as he did when he filled up before. Prob around 25 though.
                  "The Turtle"
                    Sounds about right to me.......off topic to the OP. Im in Jackson. Thought I was one of the few members from MS on here.
                    Dont drive faster than your gaurdian angel can fly
                      really man? damn me too maybe we can meet sometime and talk honda
