My cars feels like it lags a little when I accelerate at mid throttle, can this be a bad fuel filter? If I replace it do I need to close off the fuel line or can I just take the filter off? I dont want it to leak fuel in my garage.
180K on engine, time to change fuel filter?
one of those things you should of done when the engine was out.H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
well since your car isnt on, the fuel pump isnt work, there for it wont pump out gas. Alil bit may drip out, but that is about it.H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
Re: 180K on engine, time to change fuel filter?
Originally posted by Alex EX
If I replace it do I need to close off the fuel line or can I just take the filter off? I dont want it to leak fuel in my garage.-'93 Accord EX 5-speed F22A6
-DIY mesh grill, DIY stealth intake
i just did my fuel filter yesterday. It was pretty hard to get those bolts off, but did eventually get it after using wd40. But then it was leaking, cause the bolts werent cranked down all the way, after that it was cool.
so what tool is used to remove the EGR plugs?
