Smog time "Cali" ugh
    yep so i gotta smog the CB im already 2 months over do on my reg lol but now i gotta pull the intake and swap out the e-cutout for the cat, hide my header and pray that my h23 intake mani with h22 plenum passes i dont have the FITV do you guys think it will mater?? the 272 cam passed when i went to the ref last time so im good their.
    http://www.cb7tuner.com/vbb/showthread.php?t=91030 <--MY RIDE!
    http://www.cb7tuner.com/vbb/showthread.php?t=140230 <--MY ongoing ENGINE BUILD!..
    FITV is only for cold starts. for some reason it can also affect idle as well.
    272 cam passes smog? thats kinda good to know.
      yeah it sucks when its cold she wont run for nothin lol but yeah i was nervous when i went to the ref i didnt tell him i have a cam i just crossed my fingers lol but it passed unless its not a true 272 cuz i bought it off ebay, but it says 272 in the end of the cam it just looks like somone used a dremel to do it, idk how delta marks them?? but it pulls HARD to red line and thats on the stock ecu.
        when did you have it reffed? was it recently...did they put it on the dyno?
        Im in a smog program so i may be able to help.
        but your h23 mani should be fine as long as all vac lines are in tact like the h22 was.
        Retro!
        Hater
          umm it was a few months back mabey 6 months idk, but no dyno just an inspection and tail pipe test, and yeah all the vac lines are hooked up. so cross your fingers guys im going today lol fuckin $150 for tags cuz im late plus 50 for a smog ugh stupid!
            i was going to say, i tihnk you'd fail on a dyno.
            mine didnt run worth a shit off the stock ecu.
              what area you live in?
              Retro!
              Hater
                Yuba City is a type 1, no dyno, just two speed idle (unless they changed it in the last year).
                I'd say that if you passed the ref you'll probably pass smog. The person probably won't even realize that the manifold is there.
                1992 Prelude S w/swapped H22A
                  Cali is one of the worst places to have a modified car with all of these laws and restrictions on vehicles. But nice weather
                  Originally posted by visualpoet
                  some owners think it's the best thing since titties
                    thats great, non enhanced areas. Yea you should be ok, get that CAT heated up then go in for the smog, be at least 50-75% gas in your tank so they can do the evap test as well. Dont be full or empty.
                    Retro!
                    Hater
                      okay so i went in on friday and didnt pass inspection because of the map sensor on the h22 throttle body wasnt pluged in so im going to unplug the stock f22 map sensor and use the h22 one because if that woulndt have stood out i would have been golden.
                        the map sensor or the tp sensor on the TB?
                        Retro!
                        Hater
                          the map sensor thats directly on top of the tb
