in the process of removing my rear motor mount today, i had to remove the first heater hose, and the hose was stuck so i used pliers, but didnt know the strength of the hose fitting was so damn soft, u can say i crimped the s.o.b, i kinda got it back right but it leaks like shit now, is this part replacable, or am i screwed, dont have pic right now but to get a good pic in your head its the two ports where the heater hoses go in the back by the rear mount
Damn it!!! ok guys i need ya help
Originally posted by H22A91CB7 View Postin the process of removing my rear motor mount today, i had to remove the first heater hose, and the hose was stuck so i used pliers, but didnt know the strength of the hose fitting was so damn soft, u can say i crimped the s.o.b, i kinda got it back right but it leaks like shit now, is this part replacable, or am i screwed, dont have pic right now but to get a good pic in your head its the two ports where the heater hoses go in the back by the rear mount
Try taking the hose off again and see if you can make it the correct shape. If not, you will have to replace either the heater core (which is where one those hoses go) or the valve.1992 Prelude S w/swapped H22A
Originally posted by H22A91CB7 View Postawww shit... i reshaped it to where a deep socket 10 mm would slide thru it easy, it there a certain type of tightner i should put on it, i put on the one that you squeeze with pliers and opens, then when you let go of it it tightens, would the flat head 8mm screw in one work better???
For those particular hoses I would use the original "squeeze and clamp" ones.
My 5.7 LS1 Holden Ute
you should use the ones that tight up with a screwdriver.. i dont kno the name but the more u turn it the more it tightness.
if i find a pic of it ill post it.AT WEST COAST MEET
cb7rush: who has the tongs?JDMxDB8: i got a thong on...
to get to see more of my cb click the link below.
http://www.cb7tuner.com/vbb/showthread.php?t=130922
