Since i've owned my car, the dome light/courtesy lights/chime only work occasionally. Usually when it's rainy, or very humid. The dome light works if i turn it on, but none of these other things ever seem to work on any consistant basis. Everything else works fine; my windows, other lights, locks, defroster, etc. So would the ICU be suspect? Should i buy a new one, or is there something i can resolder in there, like i did with the main relay?
should i just buy an icu?
does ur door pins work? like do u see the indicator on the dash turn on and off when u open and close the door?What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by accordztech View Postdoes ur door pins work? like do u see the indicator on the dash turn on and off when u open and close the door?
EDIT: hmm the rear passenger one works but no other. I'll have to find out what pin the wires go to in the icu and test them individually, or just short the terminal on something. I cleaned those switches but maybe they're beyond saving.
SUPER EDIT: Ok, so if you ever rhetorically ask yourself, "three switches cant go bad at once, can they?" then it means that you will be proven wrong. I just swapped that rear one to the drivers door and it works so i'm gonna clean them all
MEGA EDIT: I just discovered that the leading pad on the contact seems to wear faster than the trailing one, so i popped the little metal piece out that sits inside the slide and turned it the other way and in addition to scraping the contacts off with a flathead seems to have it working perfectly.Last edited by bmxfelon420; 06-29-2009, 08:15 PM.Cars:
91 Accord LX Sedan (sold)
98 Accord LX Sedan
95 Eagle Talon TSI AWD (E3 16G, PTE 780cc, Godspeed FMIC)
so does ur dome light turn on and off accordingly to ur doors?What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
