picked up a 93 accord for $500 wont start, no fuel at the rail, checked fuel filter intake hose no fuel there either im assuming it needs a fuel pump didnt see any fuel pump fuses to check. Any advice. Also how difficult is the fuel pump to do.
Di I need fuel pump
No I dont hear anything, hoping it might be the main relay but i dont know if that would stop fuel at the rail. I got it running to my house by starting fluid in the throttle body. Once it fired up ran good. Let it sit for a few months tried to start it yesterday by priming again and nothing just cranks.
could also be a main relay. check grounds also. and def do what ^^^ said and listen to see if pump primes after turning the key to ign.
posted at same time lol. yeah check main relay, much cheaper/easier fix first, and not a bad thing to replace regardlessLast edited by bagoon316; 05-22-2009, 06:58 PM.
Originally posted by d112crzySo you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
