i dont want to start out w/ a story, but basically it progessively got worse while driving, until one day it wouldnt go into gear. it shifts through the gears fine when its off, wont go into any gear when its running. bled the system and made sure the pressure was good in the lines. pedal feels ok, normal, and when the pedal is held in it presses the fork solid. the tranny is the original from the f22 mated to an H22 i put in last year. i replaced all the clutch components and flywheel when i did the swap...
thanks everyone!
thanks everyone!
