Push the clutch and nothing happens..
    So, i go to leave today, and found that when I push the clutch, it falls to the floor.
    Wtf is wrong?
    It has fluid..Is that little thing in the fluid bottle supposed to float?
    http://www.cb7tuner.com/vbb/showthread.php?t=188155
    Bought from: ChampCoupe
    Sold to:Losiracer2
    throat bearing broke? idk..
    or preasure plate..
    probbably something in the clutch..
    or the linkage..
    Ride: 2002 Lexus IS300
      Check your clutch master and slave cylinder, I had this problem happen on my 85 rx7, the slave cylinder needed to be rebuilt, after that it was fine.
        first check to see if your slave moves when you hit the clutch and go from there.
        member ride thread
        DIVULGE MOTORSPORTS
          I have a new slave cylinder, thats not the problem, what else could be wrong?
          Sold to:Losiracer2
            you may have a new slave thats fine but when you push on the clutch does the rod move on the slave cylinder?
            member ride thread
            DIVULGE MOTORSPORTS
              nope.
              My clutch also doesnt have any resistance.
              Sold to:Losiracer2
                if the slave is not working the first thing i would do is re bleed your clutch line. if that doesnt work id suggest replacing your clutch master. its not uncommon for a master cylinder to go when the slave is replaced ive allways in my automotive career suggested to replace both at the same time.
                member ride thread
                DIVULGE MOTORSPORTS
                  i'll have to go get one tomorrow.
                  How sure are you that this is the problem?
                  Sold to:Losiracer2
                    im sure because if the slave cylinder doesnt move than anything beyond that can be eliminated. only things that are in line before the slave is the lines and the master. try to bleed toe clutch again and see if it works before you spend money. may have just not bled it propperly.
                    member ride thread
                    DIVULGE MOTORSPORTS
                      I changed the Master Cylinder today, and I must say, I'm highly pissed off.
                      Nothing works..
                      The clutch pulls itself to the floor now.
                      What else could possibly be wrong?
                      Sold to:Losiracer2
                        sounds like you didnt bleed it propperly
                        member ride thread
                        DIVULGE MOTORSPORTS
                          did you adjust the clutch master cylinder?
                            My dad bled it, he's a mechanic, but he cant seem to find the problem.
                            Sold to:Losiracer2
                              elaborate?
                              Sold to:Losiracer2
