my cb7 wont start it started well earlier ago it just doesnt even crank ... i checked the oil and it was low it didn't even show on the dipstick so i added some ....do you think its a piston seize?.....the starter clicks but thats about it
need help!!!
Originally posted by rubennebur View Postmy cb7 wont start it started well earlier ago it just doesnt even crank ... i checked the oil and it was low it didn't even show on the dipstick so i added some ....do you think its a piston seize?.....the starter clicks but thats about it
ok, you can hear starter click but maby still not have sufficient power for crank.
Check the contacts on battery, take it off clean and put again.
Also can be a contacts inside starter - starter click but do not turn starter motor on...
You can check voltage on it, ask somebody to turn key for starter position and measure voltage between ground and fat positive contact on starter.
let us know if its work
