hey guys i was wondering...if i dont have enough oil in the engine could that prevent me from being able to start my car...if so how would i know i'm low on oil...besides checking the dip stick. because i noticed as i was trying to start my car last night the oil light acted funky. lol i know this sounds like a noob ? but can anyone please help.
car won't start
car won't start
~CB7 Phoenix~
(picture missing help me get a new one)
The California White Tux
*and its alive!! hahaha*
*under construction*M.R.T: http://www.cb7tuner.com/vbb/showthre...=1#post1689652 *changes soon to take over*Tags: None
anyone?~CB7 Phoenix~
then get some oil.
probably somethingi else but get some oil.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
well i don't wanna if its not the problem i cant just dump a quart of oil in there and expect it to run like that because if oil is fine then that means 4qt oil + 1qt= 5qts too much~CB7 Phoenix~
first off you havent told me any symptoms. Does it crank, does it crank slow, does it start sometimes or did it work then you did some work to it. does it do it in the morning, only when its hot...things like that.
and you would KNOW there is enough oil if you check that little thing that goes into your oil pan called the dipstick, usually its on the drivers side of the car right behind the power steering pump. and you would know if you had enough if you looked to see if that oil was between the 2 dots. im not saying just add a quart even though there is enough fluid in there. use common sense.
and if ur 1 quart low on oil just put some anyway. its like saying since your tire still rolls you dont need to put air in it yet.
otherwise there is no way that anyone can help you. ANYONE.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by accordztech View Postfirst off you havent told me any symptoms. Does it crank, does it crank slow, does it start sometimes or did it work then you did some work to it. does it do it in the morning, only when its hot...things like that.
otherwise there is no way that anyone can help you. ANYONE.~CB7 Phoenix~
then check if there is enough oil, add accordingly.
do you have spark?What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by accordztech View Postthen check if there is enough oil, add accordingly.
do you have spark?
yes i believe so~CB7 Phoenix~
Originally posted by wed3k View Postso if you havent checked dizzy and fuel, then what have you checked? do you know how to check oil?~CB7 Phoenix~
Still no description of the actual fault.
Does the car crank at all?
Did it just not start one day, or has it been getting worse over time?
Where is the oil reading on the dipstick right now?
Theres hundreds of reasons why cars won't start - Broken cambelt, main relay, starter motor, fuel pump etc.
But we can't help you properly without any info
My 5.7 LS1 Holden Ute
Originally posted by wed3k View Postif i was in sac, id help you out.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by Nas92 View Postyes everything works fine turns over but wont start i have checked mostly everything except dizzy and fuel pump/compression...yeah i know bout the dipstick but i said besides the dipstick...i know but if i turn out to have enough i dont wanna over fill it
Originally posted by wed3k View Postif i was in sac, id help you out.lol
~CB7 Phoenix~
