So I've been having a problem with my stock 91 ex that nobody can seem to figure out. Here the scenario:
Ill start the car in the morning and let it warm up for a few, ill start to drive and the car runs great absolutely no problems. After about 10 - 15 mins the car starts to chug and and buck so I press the gas all the way and it keeps chugging than all of a sudden it feels like it breaks free and starts to pull normal. Sometimes I cut the car off and than back onand it goes away but slammin the gas and waiting for it to kick seems to work better. Now I don't have any check engine light all the time but sometimes it does come on but when I try to jump it it just flashes real quick and doesn't stop so I turn the car off and than back on and it doesn't come back. Now I've changed the alternator, the plugs, wires, entire brand new distributor, cap rotor, fuel filter, I've cleaned out the throttle body and the egr valve, I replaced the valve cover gaskets and the little gaskets on the valve cover that go where the plugs and wires are. I even changed the main relay under the dash and its still doing it. Is there anyone out there that knows what my problem is. Pleaaaase help
