for some reason my 92 accord ex idols at 600-700 RPMs. have no idea why. has anybody come across this problem or have any idea what it might be
good but bad need help
It idles at that speed in gear or out of gear?Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
1985 Volvo 245 manual [IPD lowering springs, IPD sway bars, OEM Virgo wheels, 1977 quad round headlights, 1978 grill]
2001 Mazda B3000 SE 4x4 extended cab [stock except for CB radio]
2008 Ford Escape XLT [bone stock]
2015 Toyota Prius Three with solar roof [rear diffuser, Vision Cross wheels... cheaper than steelies!]
yea what he said, usually just adjust the idle with the idle adjustment screw on the throttle body, reset ecu and your fine.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
its just low idle, adjust the idle screw a bit reset the ecu and call it a day, though it is also not the end of the worldWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
