Hard starting when warm? Thoughts?
    OK, this has heppened a few times, but it seems like it might be starting to become a bigger issue.
    A couple of times I have stalled the car while parralele parking ... or just because Im not paying attention. After I stall it it WONT restart for about 10minutes... Cranks fine and the starter sounds good, but it just dosent fire.
    Today, I shut the car off normally, first at the gas station then later at the pizza joint. At the gas station, the car was running fine as per normal, but when I started it it cranked about 3 times more then normal. About half an hour later (wihout having shut it off) I shut it off at the pizza joint, again we running as per normal, but when I tried to re start it , NO DEAL. I had to wait about 10 minutes ... then it started fine.
    Has anyone had a similar issue, or any idea what it could be? The fact that its intermitant only makes it harder to diagnose.
    Members Ride Thread - http://www.cb7tuner.com/vbb/showthread.php?t=121452
    Originally posted by slammed4thgen
    dustin, you are a dick!
    officially the lowest ive seen now
    Check your main relay and ICM (Ignition control module) inside the distributor.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      Is there a specific test procedure?
        main relay. happens to me wen i shut off the car n try n start it within 10 minutes. try turning on the car (wait till the cel turns off) then start it. this helps me out.
        to fix the relay jus resolder the connections. search the diy section for a write up. common problem on cb's.
        alone in this game . ::My Ride My Way::
          take your cuise control computer out and tap on the relay the next time it does that and it should start right up. I use to carry a long extension just for that but ended buying a relay.
          -1991 Honda Accord LX H22a-
            I couldnt find that DIY ... link?
              my money's on the main relay.
              http://www.cb7tuner.com/vbb/showthre...ght=main+relay
              later.
              Avoiding dirt at all costs
