IS this NORMAL???
    IS this NORMAL???
    I was checking the oil hose port and found some green creamy stuff in there doesnt have a distinct smell does anyone know what it is and if it supposed to be in there. I'm thinking its oil mixed with coolant judging by where it is located.
    Summer 11' Big plans (Bodywork/paint/rims etc..) in Progress STAY TUNED
    CLICK THE PIC
    i cant see jack with your finger in the way
    miss my turbo cb7
      THS STUFF IS ON THE SCREWDRIVER OOpss caps thats just the hole where it came from
      CLICK THE PIC
        bump
        CLICK THE PIC
          maybe there's a internal crack and oil and coolant got mixed
          miss my turbo cb7
            Hmmm guess i gotta do some more investigating
            CLICK THE PIC
              You also get that when you never warm up your car. Like letting it sit over night or at work for 8hrs then just taking off.
              Worst case scenario its a headgasket. But hope that is not the case.
                a bad head gasket would be alot better than a cracked block
                should be nothin to worry about, is the original oil still in the motor?...if so take out your dipstick and put a lighter up to the oil if it burns to a white color than theres most likely coolant in your oil
                http://www.cb7tuner.com/vbb/showthread.php?t=167601 Click to see my new ride
