Soft clutch
    Soft clutch
    My clutch is gettin pretty soft. Do you guys think its going bad?
    Its not going to the floor without no pressure but it dont have enought pressure as i think it should have. Its not slipping yet but the release point is kind of far back. Do you guys think im close to the time for buying a new clutch?
    2001 Chevrolet Silverado
    I'd check the fluid, or possibly bleed it again??
      Alright thanks man i was thinking about bleeding it
        It sounds like it just has air in the line. If it was going bad, I'd think it'd grind or wouldn't disengage completely
          I was hoping that was all it was going to be. I dont have the money to replace the clutch no time soon.
            Bleeding a clutch isn't hard, see if you can grab a buddy to help ya. It's tedious as hell. Here are a couple threads, hopefully the info is helpful.
            http://www.cb7tuner.com/vbb/showthre...leeding+clutch
              the fluid can be used as a reference point, if it is low from when you first instalkled the clutch, it means the material is wearing.
              I <3 G60.
