Blockoff plate
    Sweet, I think I'll run without it for a tank and then with it, and see what kind of difference it makes. Thank you for your input.
    -Jay
      Originally posted by ZigenBallZ
      You don't really have to tear anything apart...The EGR is right up top...
      the EGR gasket is like $3-4...Although for the plate I just used some copper sealant and had no leaks...
      It helped my idle from being so lopey and erratic when I had the Delta 272 in my SOHC...
      Don't be a sissy boy...
      where did you get your plate?
      did you make it yourself?
      92 DA9 // 93 D21 4x4 // 92 CB7
        I'm making mine from a soda can. I was told you can also use a piece of old headgasket.
        -Jay
          yea i dont wanna spend +$20 for a little piece of metal or aluminum.
            A friend made it for me from some sheet aluminum... it's pretty thick and he did an awesome job...
            Willie/aka v4lu3s on HS...he might sell you one for a decent price...
            But you can also just use 1 or 2 layers of soda can with some copper sealant gasket maker goo...works exactly the same and is what I was using before I got the plate from Willie...
            RIP Lifsatrip7
