I'm currently trying to put on my new Megan header and Magnaflow catalytic converter. But as some of you may know, the bolts on the stock catalytic are rusted as hell. SO... I have access to a tap and dye set. I was wondering if i could use that to cut through the rust on the end of the bolt to try and get the nut off. That and a friend of mine has a grinder he says I can borrow... I'd rather use my own tools...
what are some other options for removing rusted bolts?
thanks!
p.s.
when removing the stock header, some of the studs came out. is that a big problem or am I good if I just screw them back in?
thanks!
p.s.
