Transmission Q's
    Transmission Q's
    Hey whats up, Ive got a 1992 CB7 with the F22a1 Engine and Auto Tranny, It shifts a bit rough but with no slipping and would like to know what steps that I could take other then a flush to get it to shift a bit smoother, when I am accelerating, the depress the pedal, anywhere from 1 to 3rd gear, it tends to jerk a bit? would cleaning the shift sylinoids make any difference?
    Thanks in advance, I looked and searched the threads but came up dry, there is a about a million combinations now with how many people are on here.
    Thanks again
    http://www.cb7tuner.com/vbb/showthread.php?t=121793
    Don't flush it.
    Drain the old fluid and get the Honda ATF. Thats about the only thing the tranny is picky about. The right fluid.
      I did a full flush about a year ago with some Pennzoil ATF-Z1 compatible Import ATF, took about 8 quarts but was well worth it, shifts nice and firm.
      wat?
        Originally posted by bruno8747 View Post
        Don't flush it.
        do what he said
        drive for 3 week drain and refill with honda atf only about 2.8 q each time, after that drain and refill yearly hth
        scion Tc
        HONDA FIT
          i also have a 92 lx auto and it shifts hard too-so i bought 3 qrts of honda atf and i will let you know how my turns out also
