I cant get my crank pulley bolt off my h22 the block is in my garage on a dolly (so i cant be to rough or my motor will fall).
I need to get in there so i can finish painting and check my timing, seals etc.......
i have an airgun but its not strong enough to hit it off (max psi 125) i tried wedging the flywheel but thats a no go motor will fall with to much force..
What to do???
ANother question off topic wut solutions should i use to clean the inside of my tranny, its all gunked up ???
What to do???
