ok...i have a JDM H22A with the internal coil dizzy. When i tried to crank the car, it cranked, but then i heard a loud pop and the car just stopped trying to crank. I checked the code and it gave me a code 15, which is Ignition output signal. It sounded like the car backfired. What do you guys think the problem is?
Cranking Car Then Loud Pop!
Code 15 is tied to either your coil or your ignitor.
Does your starter turn? If not, your battery is probably too weak. If your voltage gets below a certain point, it won't turn over at all, but your radio/everything will still work.
Really, I'd be concerned about that pop. Did you loose a belt?1992 Prelude S w/swapped H22A
make sure its not 180 deg off on the dizzy
PSN ID's:Tidashoni
1992 Accord EX Coupe
My FS Thread
Not so DD 2013 Subaru Impreza WRX STI
Originally posted by deevergoteBoosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
or the dizzy got wet"you can catch me swoopin 4G coupin switchin lanes" haha haha.
1993 SE coupe drag car ahoy!
1992 EX coupe 5 spd **sold **
Did work for: jhoff_cb7
Originally posted by benji View PostCode 15 is tied to either your coil or your ignitor.
Originally posted by d112crzy View PostIt STOPPED cranking? So it doesn't turn over anymore? If you have power, then I'd check your timing belt/camshaft to make sure neither broke.
Then check your coil/ignitor.
you could have had a valve stick, and when the piston came up it bent and poped back up making a loud pop.
my replcement motor had 4 valves sticking. we were able to loosen 3 and then fired it up with our fingers crossed... it popped 3 times really loud and thank goodness it fixed it'sself."Self Renewed"
1. Even though the jdm importer might be reputable it doesnt mean they always get a good engine.
2. If your timing belt was fine did you check if it jumped alignment.
3. Check your firing order to make sure it is correct.
4. If you want to go more in depth comp test all 4 cylinders to make sure the engine is good.
got it started, firing order was wrong and i switched my distributor and cap. Thanks everybodyLast edited by lilpat93accord; 02-12-2009, 11:54 AM.
