im getting about 30 mpg mixed city and highway. thats with me getting on it a lot too. proper maintenance and a/f ratio make a difference.
O2 sensor replacement !
Originally posted by ikayto View Postnew from honda or aftermarket?
if it's aftermarket, i give it a week or a month before it fails.
Did mine today...thanks for the motorvation.
Hope my taillight doesn't turn black from exhaust again.
The H22 Sleeper Sedan, updated 8/14
After 4 months down...It's back! and tucked.
Need a Swap or some work done in the DC/MD/VA/WV area?
PM me and get it done right!
more POWA' from an 02 sensor...???...
ima get me some! lol
My Ride thread
Flickr
Originally posted by d112crzyAnd it can only get better. That's the best part.
All I gotta really say is:
just ordered and ngk for my integra, i did spark plugs, wires, dist. cap and rotor, fuel filter, lucas fuel injector cleaner and im still getting 200miles per tank, thats not what your supposed to get from a 1.8, so the only thing left is the o2 sensor, i think it might be the original one in there right now, i did pick up a few more after putting in the short ram intake
Originally posted by 10thAnnCB7 View Postwhere can i order a NGK o2 sensor and does the cb7s have a front and back ? im looking to replace them and is there a DYI for this .. seems like a simple unscrew/screw splice together ..key word "seems" ..lol
thanks
The O2 sensor is located behind the catalytic converter if you've got the F22a6 engine (EX or SE model).
Originally posted by phantomcow2 View PostThe CB7 has just one O2 sensor. It is located on the exhaust manifold underneath the heat shield. Replacement is so simple that it may not even need a DIY: unscrew the old sensor (22mm wrench), screw in new one. It'll just clip right into the factory harness, no splicing necessary.
there are 2 locations for the O2 sensor depending on what engine you have. f22a1's sensor is on the header and the f22a4/f22a6 is right before the cat converter on the downpipe. make sure you buy the right one for your motor, or else youre going to have to splice some wires, because the plugs are different between the f22a1 and the a4/a6
Originally posted by TheNextAZN View Postquick question, would h22 guys have to buy a o2 sensor for the h22a/a1/aX, or a o2 sensor for their previous f22a1/a4/a6 ?
You would use whatever o2 sensor goes with your engine.
I will not put an o2 sensor for an 84 celica/supra's engine in my 84 celica/supra that is powered by a 94 1uz-fe...same with your honda engines...doesn't matter the car body...but the engineLast edited by bcjammerx; 02-23-2009, 04:00 AM.____
