car starts fine and idles fine but stutters in gear WTF
    car starts fine and idles fine but stutters in 2nd gear and 3rd gear. But when i rev it in neutral it revs fine and smooth. What the heck is going on?
    91 Accord EX Coupe
    My pics Thread
    I play for the team I own...
    From your very vague description my very vague guess is suspension or clutch.
    Detailed symptoms?
    Take that freek show to the park, maybe the squirrels will care.
      well, as i drive its not stutter as if the clutch is not engaging its like i lose power and it feels like an old deisel engine when im in 3rd gear (putt-putt) but its not instantly. After a couple miles then it will start doing that.
      91 Accord EX Coupe
      My pics Thread
        automatic transmission im assuming?
        I <3 G60.
          Automatics don't have clutches per say.
          wat?
            they do have clutch packs.
            I <3 G60.
              do a quick check of your igintion system . it's common to run poor under load and fine at idle.
              plugs
              leads (cracks , oil soaked)
              cap
              rotor
              if these all look good and you don't see any arcing between the plug wires it should be ok,
              hope this helps, post some more details and i'm sure your recieve more help
              96 Accord SiR driveline installed. CF2 donar
                fuel injectors. that should do the trick
                  hmmm when did u start noticing the symptoms? u do any changes to the car before this happened?
                  and just to get this straight, when you are driving in 2nd gear, assuming it's about 2k rpm or cruising rpms, the car begins to stutter/lose power?
                  i rep cb7tuner all day, everyday. people say, "fuck y0 honda." and i say, "bitch, please."
                    This is the SAME ISSUE WITH MEEEEEEE!!!!
                    Srrry...i need to know!!!!
                    *Needs*
                    -New shocks
                    -Struts
                    -Drop
                    -Cleaning
                    -New Tires/Wheels
                    -New Window Tint
                    -Alot more lovin'
