ticking sound when accelerating
    just as the title states. whenever i accelerate i hear this ticking noise. This ticking noise is heard at around 1900rpm-2000 i would say it ticks about 3-ticks per second, then at around 3000 rpm the ticking noise becomes like a clatter.
    If my foot is not on the accelerator pedal then the ticking noise does not occur.
    The weird thing is that in neutral and revving the motor, the ticking around 1900-2000rpm is not heard, but the clattering noise is still audible at 3000rpm.
    Thanks for any help.
    Its the ultra rare jdm bomb
      checked valve lash?
        Id say valve lash also, could be throwout bearing and axles?
        ..It's not cheap to build a fast CB7, especially NA. However, if you're willing to put the money into the car, it's well worth it in the end. There ARE faster cars out there, but some people, like me, want THIS particular car to be fast!...
        Sold to:tanNn2koo,9tAkord,ThrakBarts,nahmo,andrizzle,or anger
        1993 H22A cb7 <3 miss you
        04 WRX stg 2 sedan
        Current - 02 WRX stg 2 wagon
          i had a subtle exhaust leak that sounded a little like what your explaining. but it was whenever i was moving. i could rev like mad and nothing(although, i could have not heard it over the exhaust) but when i was moving and on it there it was.
          Thought it had something to do with my switch to synthetic oil.
          Then i went Dukes and made it worse. but i narrowed it down
          but as for you, most likely valve clatter. Valve lash is a bitch.
