i was driving my car like 3 days ago and all of sudden my oil light came on,i stop check the engine oil...its go0d it has wat it supposed to have,as i start the car again the light is off,but after driving for few more blocks i stopped at a light and i signal and the oild light came up again,as soon as i took off and turned off the signal light the oil light went off,so as i was putting my signal or hazard light my oil light would come up,now what could it be??? thanks in advance
Oil Light Coming out!!
Originally posted by CB7Man View PostActually it could be old sauder inside of your cluster....
I lost my Fuel and temp guages because of it.
If it loses connection and then comes back, it will flash, which probally indicades a wire/sauder problem.
Or your oil pump is about to die...so...bend over and shell out the dough!Last edited by USDM_CB7; 01-06-2009, 02:40 AM.I Miss My Cb7!
1)check your oil
2)whens the last time you changed your oil
3)change your oil pressure switch
4)make sure that your not leaking any oil
5)are you burning alot of oil to the point you have to keep refilling the shit everyday
6)broken or loose connection between switch and connector
)worst case scenerio oil pump is on its way out better have another long-block on the side for a swap.Last edited by h22sparkle; 01-06-2009, 03:31 PM.
Replace the oil pressure switch.1st car: Frost White 1991 Accord EX sedan.. (Dec. 1999 ~ Jan. 2001) *Sold*
2nd car: Black Pearl 1993 Accord 10th Anniversary sedan (Feb. 10, 2003 ~ Mar. 8, 2008) *Sold*
3rd car: Frost White 1992 Accord EX sedan (Jan. 15, 2008 ~ Aug. 12, 2008) *RIP*
4th car: Seattle Silver 1991 Accord EX coupe 5MT (Aug. 13, 2011 ~ Mar. 19, 2014) *Sold*
5th car: Black Pearl 1994 Accord LX coupe 5MT (Mar. 1, 2014 ~ )
Originally posted by USDM_CB7 View Posti was driving my car like 3 days ago and all of sudden my oil light came on,i stop check the engine oil...its go0d it has wat it supposed to have,as i start the car again the light is off,but after driving for few more blocks i stopped at a light and i signal and the oild light came up again,as soon as i took off and turned off the signal light the oil light went off,so as i was putting my signal or hazard light my oil light would come up,now what could it be??? thanks in advance
but..mine is when Im at a complete stop...in D4...when I put it in Park..or Reverse..it goes away..when I shut the car off...and turn it back on...it goes away...
so far..its done it 3 times in the past 2 weeks
checked oil..and oil is good.
so ..I would assume a few things thats a known factor..
1) oil pressure switch.
2) oil pump is going bad
3) worn engine bearings.
I think..its time for a swap for me.92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
MR Thread:
