I am in the process of getting my OEM flywheel lightened. I was told not to worry about getting it balanced, which sounds odd to me. I was told that it would be even because the same came off all the way around. Is this correct?
Flywheel Question....
buy fidenza or clutchmasters, lighted factory units can shatter. how many miles are already on your flywheel too. just replace it. whyte7 has one and loves it and i drove it and its incredible at highway speeds.JDM H22a
P2T4 tranny
I/E, CM ultra-light flywheel and CM stage 1 clutch
16x7 Rota C8's in bronze
nitto neo gen, 205/50/16
custom short throw shifter
Tokico Illumina RAK Coilovers
Power Stop Cross-Drilled Rotors, Honda Pads
Honda Torneo Shift Boot and Knob
Well it is only about $100 for an Exedy OEM replacement flywheel at clutchcityonline.com. I think mine was like $110 shipped or something like that. It was cheap and MUCH more reliable than having it machined down and thus lightening it. But that is only if you are planning to stay OEM. If you go lightweight, I would go with one of the above recommendations. I have heard good things about them and would have gotten one myself but my wallet was not for it."This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
FS Part out thread koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
I had my stocker lightened...
It made a noticeable difference... butnothing like an 8lb Fidanza...which you can get for $200 shipped if you shop around...
Anyways though... I had mine balanced... I paid about 60 total for the turning and balancing... Didn't have any problems with mine...
I don't know if the work to pull it out was worth the slight amount of freed up rotating mass... but if you have it out already then why not... it might be worth it then....
but don't kid yourself... you can't take off that much weight maybe 5 lbs safely...
It won't compare to a prefabbed lighter flywheel...it's a good lowbuck mod though if you're not expecting too much...RIP Lifsatrip7
