three problems in one day
    it all started yesterday i came out of a friends house and openend the door n my dome light was out then i started the car to turn da rear defroster on n it didnt click in then wen i stopped the car to go get some thing to eat i took my deck out n tha antenna wouldnt go down like it usually does so can any one help me thanks
    all thats simple stuff dont worry about it. check your fuses.
    nija edit. 400th post!
      aiight bro ill check dat tommorrow cuz i got work today so yea thanks fo tha help
        the problem for your dome light might be from the button on both sides of your door. if that button gets stuck or something, then it wont go on. Try pressing it a few times and see what happens
        MY CB7
        FULL part out thread:
        http://www.cb7tuner.com/vbb/showthread.php?t=204494
          - Antenna crapping out
          - Check your dome light
          - Check your defrster switch
          - Use proper sentences , it's not that hard
          1996 Honda Civic LX 2009-2012
          2012 Kia Optima LX 2012-2013
            i am sorry for using uncomplete sentences. i went to pepboys yesterday and it turned out that i needed a new battery.I got a new battery. the dome light is still not working same with the rear defrost. so i will try the side switches on the door. Cakeboy would i need to get a new antenna? ill check the fuses tommorrow because i have work yet again thanks a again i will let you all know thanks
              Do you hear the antenna motor running?
              If yes, then yes you need a new one.
                i cant hear the antenna motor running i also tried pushing the switch on the door to see if the dome light would would go on but it didnt. also i went to block buster to return a movie and wen i came out my car wouldnt start so i sat there in the parking lot and yet again tried to start it again and it started but barely so i reved it and it was workin fine so any suggestions ? thanks
                  Looks like your light is burned out.
                  Check your ignition coil wire.
                    ok ill check the ignition coil wire tommorrow because its too late to check it now so ill let u know wat the problem is and also wat would be the issue with my cigarette lighter ?
                      its just the fuse under the hood. the samething happened to me last week just test all the fuses and just change it i forgot which 1 i change lol the my lighter, domelight, and my alarm was telling me that there was a door open which there was not, so i just changed a fuse
                      MEMBERS RIDE.
                      Bought from: DannyD , Night Wolf , CB7=91, lummieCB7
                      Sold to: LITuner, rezist09, Pacman91EX, 93AccordLXwhite, PhatAccord, TheNextEpisode
                        ok ill check da fuses and the coil thanks to all imma go so ill let you all know how it went thankyou
                          You should get a test light.
                            hey everyone i checked the fuses and it turns out that four fuses were blown so yea i replaced those and now everything seems to be working so thanks again for the tips thankyou
                              When the dome light, defrost, and other stuff dont work at the same time then its the ICU. I replaced and bam I got my corners, dome light, and defrost back. Something else to check into.
