it all started yesterday i came out of a friends house and openend the door n my dome light was out then i started the car to turn da rear defroster on n it didnt click in then wen i stopped the car to go get some thing to eat i took my deck out n tha antenna wouldnt go down like it usually does so can any one help me thanks
three problems in one day
- Antenna crapping out
- Check your dome light
- Check your defrster switch
- Use proper sentences , it's not that hard
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
i am sorry for using uncomplete sentences. i went to pepboys yesterday and it turned out that i needed a new battery.I got a new battery. the dome light is still not working same with the rear defrost. so i will try the side switches on the door. Cakeboy would i need to get a new antenna? ill check the fuses tommorrow because i have work yet again thanks a again i will let you all know thanks
Originally posted by yaboi jeff View Posti am sorry for using uncomplete sentences. i went to pepboys yesterday and it turned out that i needed a new battery.I got a new battery. the dome light is still not working same with the rear defrost. so i will try the side switches on the door. Cakeboy would i need to get a new antenna? ill check the fuses tommorrow because i have work yet again thanks a again i will let you all know thanks
If yes, then yes you need a new one.
i cant hear the antenna motor running i also tried pushing the switch on the door to see if the dome light would would go on but it didnt. also i went to block buster to return a movie and wen i came out my car wouldnt start so i sat there in the parking lot and yet again tried to start it again and it started but barely so i reved it and it was workin fine so any suggestions ? thanks
its just the fuse under the hood. the samething happened to me last week just test all the fuses and just change it i forgot which 1 i change lol the my lighter, domelight, and my alarm was telling me that there was a door open which there was not, so i just changed a fuse
MEMBERS RIDE.
Bought from: DannyD , Night Wolf , CB7=91, lummieCB7
Sold to: LITuner, rezist09, Pacman91EX, 93AccordLXwhite, PhatAccord, TheNextEpisode
