Well, sounds like the F22B DOHC that I just dropped in a little over a year ago has issues with the con rod bearings. I hear the knocking/tapping sound honeslty after I was running an 08 SI. 7K shifts. Turns ou I had an oil leak I didnt notice so I was a little lower on oil than I usually am. I had about 1 qt when I checked it after that. I added another quart and it quiet down a bit but I hear it anywhere over 2800rpm more audibly when the load from the tranny is put upon the engine. Its actually not severe right now or not too loud. I actually thought it was the distributor shaft at first, thats how quiet it was. Anyway. Heres my question, If the bearings are bad, and you had access to a H22 block, would you replace the F22B bearings or put the H22 bock in. Time and money is a factor. What would be faster??, I can get the block at a very good deal, probably just as much as the bearings.
I havent cracked that oul pan in a while so I forgot if the rod bearing can be changed after the main bearings and oil pan come down.
Also what bearings are best to order for this engine, H22a, F22a, or H23a, F23a?? Any advice is appreciatted, I wanna get the ball rolling by tomorrow. Chill
