I recently changed my oil from conventional to synthetic. I grabbed Quaker State HP oil because it was on sale and iwanted to switch to synthetic anyway.
Right after, i start hearing a lot more valve noise. I know H22's make plenty of it, but it's a different tick. almost sounds like injectors just really loud.
I'm not sure if it's the same sound, but at the same time, i can hear something similar, only when im accelarating. I thought it was my exhaust leak since i was missing a bolt at the end of the DP but i got one on and it's tight. still there.
It's a little weird because it sounds like a mixture of valve tick, detonation, and sounds like i have a hole in my exhaust. but it happens mostly in second gear or higher. I can't hear it in VTEC because it's not THAT loud. but enough for me to not want to accelarate much. also does it more with a WOT at low RPM's.
and i can't hear it at all when it's in neutral. but idk if i just can't hear it, or if it's not making the noise.
I am uber paranoid about shit like this. Any suggestions will be tremendously helpful.
