Anyway if you had abs you would have an ABS light on your cluster, rear disk, a huge reservoir next to the intake tube, a huge ABS motor under the battery.
abs axles will work fine in an non-abs accords. matter of fact, i have abs axles. later.
Thanks for the heads up, I ended up finding this out when I returned to my supplier to check the part number on the core for my passenger's side axle.. this is very good news, now I can make the swap tomorrow
