Crank pulley removal, need some ideas
    Hey,
    I need to remove the crank pulley (the engine is out of the car)
    I used to bolt a flexplate to the crank and then use a big screwdriver to prevent the flexplate from moving. Then I unbolted the crankshalf pulley that way without any problems.
    Now I can't find a flex plate and can't think of anything else I can do to prevent the crankshaft from moving. The flywheel only has small holes in it....so I could insert a screwdriver in there to prevent it from moving... but I think it will just bend because I would have to use a very skinny screwdriver.
    Any ideas?
    get a thicker one or a pry bar,one of my drivers bent I just use it now for wedging stuff and bought me a new one.
    Summer 11' Big plans (Bodywork/paint/rims etc..) in Progress STAY TUNED
    CLICK THE PIC
      http://www.clipsandfasteners.com/Pro...tCode=AT648796
      There you go.
      Finally Up and Running. Numbers to Follow. Check my MR
        Originally posted by mayberry View Post
        x2, bought mine from Amazon.com
        Click Image for CB7Tuner.com Beanies, Decals, & Keychains!
          Originally posted by rexload View Post
          Hey,
          Any ideas?
          find the fattest screwdriver you can fit in those holes. It works. I've done it plenty of times.
          Or just invest in one of the best tools ever made for Hondas.
            u can make the tool
            just get 2 nuts that will fit there (gas station fuel hose nuts)
            weld them togheter to ur ball joint separator tool, make sure a 19mm socket can slide in the 2 nuts
            Just do what PR CB7 said.
              i'm having a simliar problem too. i'm rying to chang out my tbelt and the crank bolt is on good. (check my post about me losing 8 quarts of oil)
              i even tried to put the car in 5th and stand on the brake and the clutch is not holding
              hayes says to stick the screwdriver in the flywheel but i'm iffy on that
              impact wrench won't get it off too. so imight as well invest in that honda crank tool
              1991 White Accord LX 5-speed aka Lil' Red
                same here. Ive used it many times
                93 Accord LX Sedan (sold)
                  Yea I am not sure about spending $30 on a tool I don't really need....
                  Thanks, I'll try it
                  Originally posted by PR CB7 View Post
                  u can make the tool
                  so you can get these nuts at a gas stations? I may just make my own tool, that's a great idea!
                  Well the flywheel is not going to break from this
                  The screwdriver will bend before you do any damage to the flywheel
                  I am going to just do it this way, just gotta find a pretty strong screwdriver
                  If you cannot get the crank bolt to turn, I recommend getting a very BIG cheater bar, you can apply A LOT of force to it that way
                    Thanks, I'll try it
                    we did lol an 8 foot bar with two guys on it the clutch was slipping, wont hold
                      The tool is worth the $30, even if you only use it once. Which I doubt.
                        try to source the tool for cheaper elsewhere. The tool is amazing.
                        ...adjust accordingly
                          lol I said the same thing before buy it. so far Ive used it 4-5 times
                          it beats damaging the engine or the other tools
                            i used a chain type pulley wrench
                            this is what i used, works great, but it does leave behind some teeth marks. wont really hurt the crank belt afterwards.
                            tried doing it the haynes manual way, hell no, didnt work out for shit.
                            air gun will probably break it loose too.
