Okay maybe you guys might be able to help me out with this weird but someone wat sounds like a no brainer.. but let me hear wat you guys may think?
The new accord i am getting tomm the only prob the owner saids is wrong is the clutch.. he saids it still catches gears but wont for too long and needs to be changed. Now here is the weird part... the clutch pedal is dropped to the bottom of the floor board!!
So wat are some of the possible problems it can be? needs new Clutch master cylinder? Needs Fluid to give it pressure again? cut line somewhere?
Any Ideas or if anyone has had this problem and knows a solution or insight to it would be greatly appreciated! thanks in advance.
