02 Sensor Wiring problem on H23
    Here's the layout of the problem...i have a 90 accord, 96 H23 and 93 P14 ECU...I have everything else wired properly but i keep kicking 2 CELs, 1 and 43. I have re-wired the o2 sensor well over 10 times and can not get the wiring straight...Does anyone know the wiring color for each wire as far as signal and heater +'s and -'s so i can get rid of my CEL's...once it lights up, the car runs like ass on that "preset" fuel curve for the motor.
    "Once a CB7 Tuner, Always a CB7 Tuner"
    Former h23 swapped accord owner...
    2002 Acura 3.2CL
    20" Rims and Brembo Brake Kit - Ridin classy and slow
    1994 MKIV TT Supra
    BPU+++ (under the knife, getting nastier)
    Well the motor technically is OBDII however the ECU is OBDI and it was previously in a 93 'lude that ran with 1 o2 sensor and was fine...I still haven't found anything on the wiring so whatever help you can lend me is really appreciated.
    2002 Acura 3.2CL
    1994 MKIV TT Supra
      You might be on to something...i'm just curious though, wouldn't it trip more codes than just 1 & 43?? Figuring just from running an OBDI computer, and she runs great until the CEL pops up.
      2002 Acura 3.2CL
      1994 MKIV TT Supra
        Well I think i found out the mystery to the o2 code...i had previously tripped EGR codes...I seemed to get rid of them but never got rid of the o2 sensor...then i was reading somewhere the o2 sensor heater + pin location and the EGR valve wire pin location were switched on prelude and accord ecu's...i'm researching that a little more but I have a feeling that might be the end to my problems...if you know anything about this, clue me in since i never heard that before
        2002 Acura 3.2CL
        1994 MKIV TT Supra
