within this coming week i will b replacing my passenger front window is ther ne idea of how to do this ive done it on a ford but not on a honda so can sum-1 write up like some directions if possible its highly appreciated (and o yah i have no clue if this is the right place to post this)
passenger window
sure man its easy as hell.
Step 1. You see there are a couple of holes in the door panel open the door theres one near the front you have to slightly gently pry it off and pluck it out. Then theres 1 where the door handle is on the top there a little hole cover there you have to pry that out so it can reveal the screw.
then theres another one right below it where the controls are to open and close the windows up deep down in the pit theres a screw down there but you have to remove the cover that coverin it with a screw driver., then theres another one at the end of the door towards the rear again pry the little door part towards the back. then remove the screw and the door handle itself. Be extra careful of removig it it presses in slightly andand moves out towards the right careful not to just pull it it will break if you do. dont pull it out all the way just make sure you have the plasit slightly off there should be a thin metal line still holdin on use a little screwdriver to push the plasic clip to the side and pry up the metal line holdin onto it.
Thentake thedoor panel and lift it up if it doesnt lift up make sure theres no more screws holdin onto the door still. When you pri the door upwards dont pull it off just yet you have to search the back of it and unclip the clips that connect to the door locks and power window controls. Then your done to replace the window but you may wanna leave the one with the window controls in so that you can roll the windo up and down to expose the bolts to take it off at will it requires some fidgiding here and there so good luck.
