How fast can I safely go in second gear?
    Ok, two options: Have the car towed (expensive) or drive the car in 2nd gear home, including about 25 miles of highway. While I don't want to pay for a tow truck, I also don't want to have to pay for a new tranny if I blow it. I know you're not supposed to go that fast in 2nd gear, but I can't start the car in 3rd, and I can't shift once its started... can I safely go about 50 or so the 30 miles home? Or is that going to burn the transmission up. If its safe I'd do that and save some money... otherwise I'll just play it safe and get it towed.
    go to uhaul and rent a tow dolly..less than $30-$40 thats what my uncle said..and just hook it up to a truck and tow it home
    Ride: 2002 Lexus IS300
      I thought of that, but I need to find someone with a truck (important part: that has a hitch) and I need this fixed quick. Have lots of friends with trucks, but none with the tow package for one reason or another. Thanks, though, and I'll keep looking.
        If you went 50 in 2nd that would be in the 5k range. It would be obnoxiously loud but I don't think it would kill the tranny.
        A better question is: why can't you shift?
        Gary A.K.A. Carter
        [sig killed by photobucket]
          Why waste the gas? Just get it towed. It would not damage your transmission to drive in 2nd, but it would obviously be harder on the engine since the RPM would be so high.
          "The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
            i just read your other thread... two words : rev match
              takes some gettin used to that though...if its his first time or not that great at it...sometimes it dont work out so well
              i do it in my truck all the time.
              ..[CB7][STAR]..
              MY MEMBERS RIDE THREAD
                He will learn fast lol. Semi truck drivers do it all the time i dont see why normal cars cant lol.
                  So, whats the problem?
                    wont shift into other gears, probably a hydraulic system failure.
                      Clutch related?
                        turbo incapulator related.
                          it's actually not that hard.
                          in all reality, with our cars, you can just take it out of gear and put some pressure on it into the next gear. it should fall in as soon as it's ready.
                          for down shifting, pull it out of gear, rev the motor and repeat. it shouldn't grind at all if you put enough pressure.
                            Fucking mash the gears. Dont even worry about it.
                              haha mash the gears lol my friends escort was so loose we could do that lol. Good times good times.
