h22a front mount, need to know interchange
    the cast iron mount in the front (timingbelt area) is gone and i can't seem to find one, what else has the same one. the f22a6 is slightly different. the piece that bolts to the cast arm with 12mm head bolts that attaches to the block is too short to reach the bolt hole above the waterpump
    96 Accord SiR driveline installed. CF2 donar
    another h22 one or one off a h23
    92ex coupe h22
    93 240sx with silvia front end (kadet in the works)
    http://www.cb7tuner.com/vbb/showthre...=1#post1894990
      sweet! there is one of them at the wrecker locally. so i'm down to a header and adapt the iac. then i can do the swap, thanks
