cable
    cable
    where is the speedo CABLE at??? im thinkin it mite be my problem after all i replaced the VSS but nothing now im targeting wires and relays
    no speedo cable in our cars, did you check all your fuses ?
      thats what i thought. ive been checking fuses but the wiring diagram says the ground for the VSS is in the front left engine compartment i kinda got an idea but not sure.. but point is my car was wrecked got hit by a suburban its all fixed now but could that be a problem is there relays down there? funky fuses?
        i'm not sure on what ur specific problem is .. but i'm guessing ur speedometer dosen't work? when u say u replaced the VSS .. did u just replace the top portion or did u replace the whole gear?> .. i'd suggest replacing the whole gear with a new one. I got 2 used VSS gears.. none worked.. ordered one off ebay, and that one worked. And check ur fuses, make sure everyone is pushed in.. since u said u got in an accident.. possibility some got knocked out.
        Originally posted by wed3k
        i rep cb7tuner all day, everyday. people say, "fuck y0 honda." and i say, "bitch, please."
