Couple of ?'s
    Couple of ?'s
    1.I want to remove the vacuum control box I did a little research and found out that i can run with out it, I have an map sensor on the throttle body so I'm going rewire the plug to the sensor,but what about the vacuum lines.
    2.What about the Charcoal cansiter can I run without that ad if so would happen.
    btw I have an 97 accord f22b1 motor obd2 in an 90 EX
    so someone pz help me out.
    NEW CB
    old Darkcloud : 1990 Accord EX MRT
    new
    DARKCLOUD : 90 ACCORD EX MRT
    y just leave it the way it is!
    Ride: 2002 Lexus IS300
      everything in that box is emmissions related other than the map sensor. I dont suggest removing it because you will not pass emmissions/smog without it operating.
      member ride thread
      DIVULGE MOTORSPORTS
        The black box keep it but i'm pretty sure you don't "need" the charcol canister. You only need if you have to pass emissions. Which some states you don't with our cars.(sry didn't read the year) Opps nevermind you need both of those you have a 97. You will probaly won't pass emission if you take it out.
        "The Turtle"
        DD/Trail Rig/Mud Bug
          Don't have emissions here.
          You can still pass the if your car is running well. You don't technically need the charcoal system (I can't use it with my aftermarket throttle body), the EGR, the FITV, the Air Boost valve, or the stupid vacuum box mounted on the transmission mount bracket.
          You can experiment without disassembling too much, just pull the vac lines for the part and disconnect it. plug the hose and seal the nipple on the intake manifold with a vacuum cap or temporarily with some electrical tape.
          PM me and get it done right!
            I'm planning to do a wire tuck and want to really clean up the engine that's why i'm asking if i can remove those plus want to mount an cone air filter directly on the throttle body.
            NEW CB
            new
