My front right LBJ is going. I've been meaning to change them but I don't have the tools. How do I change them????
Lower ball joint replacement: no press. How do I do it???
autozone rents tools that remove BJs, it helped mj213 and I when we had to do his BJs a couple months ago.
member's ride thread
91 Accord SE 176k
Originally posted by bruno8747 View PostI've never seen it taken out with a press, I use a pipe that fits around the joint and then beat the shit out. That always works.
Put a short pipe or a big socket over the balljoint and hammer the fuck out of it(after you remove retaining ring). Then, you'll have to loosen the 4 bolts that are on the back of the spindle to move the hub out of the way enough to slide the new lbj back in. give it a few wacks and all is good.
remove the clip, 14mm deep socket over the BJ threads, large hammer, and a lot of fucking agression.
Originally posted by Accord R33 View Postremove the clip, 14mm deep socket over the BJ threads, large hammer, and a lot of fucking agression.
Originally posted by lordojaim with you on that one bro! aint nothing beat free food and drinks any day of the week, even if its at a funeral
Originally posted by gloryaccordy View PostExactly the answer I was looking for. I have to remove the hub as well right, to get clearance?Gary A.K.A. Carter
[sig killed by photobucket]
did it on the the knuckles i put into my cb,
HAMMERTIME !!
but the BJ press is good too, i would remove the 4 bearing bolts too so they don't get damaged and while you're there put new front wheel bearings in, you gotta take 3/4 of those parts out to do the ball joints so why not go all the way, safety first
Originally posted by bobbycos View Postdid it on the the knuckles i put into my cb,
HAMMERTIME !!
Originally posted by gloryaccordy View PostTrue true, I gotta change my left axle anyways. Looks like I'm gonna have a fun time Wednesday
left axle
left lower ball joint
left wheel bearing
then consider the right side
Originally posted by bobbycos View Postdo it all and do it once !!
left axle
left wheel bearing
