Popping sound when clutch is let out!!
    I've recently noticed that every time I let the clutch out (mainly just in reverse), I can hear a popping noise that sounds like it's coming from the transmission. Is that normal, or is there something wrong with that?
    91 lx h22a
    Member's Ride Thread
    bought from: xkjnboix, new_beginnings
    It's not normal and my car does the same thing so I'm going to keep an eye on this thread. I've been thinking it's either my sorry clutch (XTD) or the rear mount. It doesn't make sense for it to be my rear mount though because I'm running the ESP full setup, however I'm NOT running the front torque mount (supposedly not needed with ESP kit).
    Check your motor mounts and also check the chassis for any loose bolts, all I can think of.
    My Member's Ride Thread
      Yeah, I have ESP mounts too, but I still have my front mount. It's not loud or anything, and it only seems to be in reverse. Like I can't hear it if I have music on at all.
      And actually to be more exact it's more of a 'ting' then a 'pop'. I'll look around for loose bolts in a couple days.
      91 lx h22a
        put the car in gear and try to rock it back and forth. check the engine bay and see if you can find what the noise is.
          I said it sounds like it's inside the transmission..
          Also once in a while when I start moving and then push the clutch back in, it sounds like something is slightly scraping on something else while spinning, then stops after about 5 seconds.
          91 lx h22a
            i think what he means is that if you put it in reverse with the car off and rock it, what ever is making the noise should continue to do so. thus without motor noise, you can narrow it down.
