Idle Issue!
    Idle Issue!
    What is the proper way to set the idle?
    Recently I got a vacuum leak from a broken hose and replaced it but the idle is off now........
    the idle is set from the factory. you haven't fixed your problem completly. later.
    Avoiding dirt at all costs
      Well I had a broken hose and replaced them all and I checked the The vacuum with a gauge and it was holding steady......
      So the idle is off slightly its at 800 on stop and go and it sits at 450 on full idle at normal temp....
      I was asking how to adjust it properly from the idle screw.........What is the procedure!
        Have you try to SEARCH about this...
        Check out this thread...
        http://www.cb7tuner.com/vbb/showthread.php?t=111879
        Sig removed due to excessive size
          oh ok that helps alot......thanks for that link!
