Will mount work?
    Will mount work?
    got a 91 mod accord with h22a motor.. swapping from auto to manuell.. Using a f series tranny... Guess its from a 91 mod accord..
    Can i use the engine mount which is from the donor car to make it fit?
    The auto engine mount will not fit even in hell...
    Accord M0DiFi3D From Norway
    Visit Website: http://www.garaget.org/?car=63883
    use the manual tranny mount you got the tranny from
      No you can't. It won't line up as the manual and auto mounts are in different locations on the chassis.
      Read here. It has some good info.
      http://www.cb7tuner.com/vbb/showthre...to+manual+swap
      3 CB's gone....
      1 WK Overland....
      Still miss the CB though......maybe one day.
        ok, so il just cut of the bracket in enginebay, and weld it back so it fit with the engine mount?
        Or should i use the manuell bracket to weld back on?
